I have air coming through the hose that goes from the crankcase to below the carb. It burned a hole through the hose. I replaced the hose, and it burned a new hole in 10 seconds. The motor won't idle, but runs ok at higher rpm. I checked the compression, and each cylinder was 120. The air coming through the hose is not continuous, but more like a blast every few seconds. Ideas? 1978 Evinrude 35hp Model 35802R
