Hi im new to this site but anyway i have a 1998 johnson 225 Ocean runner and i started it about to weeks ago. And now i have installed it on my boat and connected everything all the wiring and gauges but when i go turn the key it wont start and i know theres power cut the choke clicks but nothing else happens when i turn all the way? do u think its the neutral switch on the control box ? because theres two wires that are black and i dont know where they go everything else is fine and working! Also, i check the starter soleniod and there only power where the battery wire connects too but on the other side which connects to the starter nothing even when i trun the key!! Can some help im stuck!!
