Hello all,
I just purchased a 1979 evinrude 25 with a jet drive on it. I got it for next to nothing because the previous owner tried removing the jet in favor of a prop, and in the process, cracked the water pump trying to pry it apart. Anyway, the driveshaft is stuck in the power head. I went out and tried working on it today, and he also pulled the bearing up about 1/2 an inch, so looks like I get to rebuild the pump as well. There are no bolts holding it up, I've worked on these evinrudes since I was 10 and know my way around pretty well. Can anyone give me suggestions to get this un-stuck? I've tried prying on it, beating on it with a rubber mallet, and its not budging. my next idea is to thread the bolt back on the end with a large fender washer and hit it a few times with a slide hammer.
