jeremy5780
- May 8, 2008
- 147
1999 200 johnson ocean runner. I have been having trouble with cold starting at the ramp. It would take me 5 to 10 minutes to get the thing started I would turn the key and the engine would go vroom real quick then stop like it was not getting the fuel needed to start. Eventually after about 50 turns of the key (literally) it would start and idle rough for a bit then would run good all day, unless it sat for a few hours then would be tough to start again. I dropped it off at the marina thinking it was out of sync or timing was off just a little. They said stator was going bad and was putting out to much which in return was burning up the power pack. They replaced both and stated the motor was running like a top. What I dont understand is why this was causing hard starting but would run fine after started? any thought's or ideas?
