I have read on other post's that this can be accomplished. I just wanted to confirm a few items. I have purchased the sierra fuel pump model number 18-7353.To change over is this the correct one and do i completely remove the entire vro unit? The vro has already been changed to a premix, but i think the fuel pump is going up since i have surging when trying to get on plane,but after a while 15 min or so it will have no problem getting on plane and not bogging down. Also the pulse limiter connects to the carb but i have 3 on my motor, would i connect it to the one on the bottom?
Thank you for any help.
