67Wacanda_Guy_99403
- Oct 5, 2011
- 6
Ok, I bought a motor for my 67'wacanda from a guy in spokane! He said that it was in good running condition and being mildly ignorant and excited about a 125.00 motor I believed him. When I got it home I decided to look up some info about it before running it seeing how this is my first boat and first outboard motor, after making sure the plugs were good we took it to the water to start it. it started after about 15mins of fiddling but sounded like it was missing. I took it home and looked up the johnson owners manual for it online, it said to check the points, found out one of the magneto coils wouldnt ohm out so i replaced both coils with new OMC coils and also put a tune up kit on it! He had cross threaded the spark plug on it and tapped it out to use a machined sleeve, I repaired the plug hole with JB Weld and fix-a-thread kit specifically for spark plugs. It had a sheared flywheel key which i have also replaced and the low speed needle for the needle jet was gone i have replaced this also, what my question is I cannot get the motor to Idle and am having a hard time understanding the posts on here for tunning the carb. I am also wondering what I need to make sure has oil and grease in it to prevent from breaking anything durring the remainder of this restoration? PLEASE HELP
