Re: winterizing motor
In your case you may run it dry, however I'm not in favor if it.
Mix a small canister/tank in which you add min 5% fogging oil in addition to 4% 2-stroke oil. If running it dry, this will leave an oil film on all internal metal parts in the carb and prevent corrosion. If in addition you add some 2+4 fuel stabilizer you should not need to run it dry unless you plan for storage longer than 6 months. Empty carbs will have condensation inside as temp drops, this might be just as damaging as stale gas!
