Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1974 25 hp johnson no fire
  • 1974 25 hp johnson no fire
    Hi
    I bought a clean electric start 1974 25 hp johnson yesterday for $100.00 that has no fire at either spark plug. It looks like it has 1 new coil, the points are gapped at .020 and look good. How do you check the coil under the flywheel (think it's called a driver coil)? Any thing else that I should check? I don't have the ignition switch wiring pluged in to the motor.
    Thanks
    Bob
    Re: 1974 25 hp johnson no fire
    Unplug the kill switch leads and try it again. Use a real spark tester.
    How do you know the points are gapped correctly?
    I dream of a better world where chickens can cross the road without having their motives questioned,
    • #3
      kill switch (ignition switch) is unhooked and I am using a spark tester. I don't know that the points are gapped correctly as I don't know what they are supposed to be gapped at, I know that both sets of points are gapped at .020 as I checked them with a feeler guage.
      Thanks
      Bob
      • #4
        Next is to pull flywheel and check the coil.
        Have you got a repair manual?
        • #5
          Hi
          I have the flywheel off. I think the driver coil under the flywheel is bad as everything else looks good. I don't have a manual for it. I was hoping that someone could tell me how to check the driver coil when I first posted. I have a snap-on voltmeter and have done a ohms check with the coil unhooked from both sets of points, from wire to wire reads 0.563 ohms if that helps.
          Thanks again
          Bob
