I have bought a Johnson 25 HP engine from 1970.
I have read the forum FAQ and other related posts but did not find the answer.
I cant get my engine to start the normal way.
What do I do?
- Pump the gastank after opening the air.
- Pul the Choke
- give it a firm pull
When puch the choke back and pull it. Then sometimes its fires a couple of times and then stalls. With the choke out it does nothing.
Here's the strange thing
When I put the engine in gear and i open the throttle than put it back in nutral It will start but then the engine overrefs. When I put the throttle back it stalls again. So when i want to take a spin i have to put it in gear directly and leave it there. When it runs it runs good. The idle speed is a bit to high.
What must I do or adjust to get it tu run in nutral ?
I am from the Netherlands so please excuse my writing. I hope someone can help
What do I do?
- Pul the Choke
