Re: tilt/trim for 1988 88hp johnson outboard
Not that hard to do if you have the required tools and equipment to lift the motor off of the boat. If your controls are the ones that the 88 came with, they likely wont have the trim switch so you will have to consider that as well. Cost is dependant on where / who you buy from and how lucky you get... I always look for private sellers with complete damaged motors for sale, dealers in used outboard parts may want more $ than you want to spend.
