Blake0912
- Oct 31, 2010
- 310
I'm going to replace the water pump on my 85 25hp johnson commercial tiller, I have replaced the water pump before on my 90hp 88 johnson and also another 92 merc. But I have never replaced one with this older style LU. Someone told me in another post the linkage release bolt is actually on the leg behind a plate with two screw? I have found the plate and took it off and there is two bolts behind that..does the lower bolt release the lower unit?
