Chaparralbob
- Jun 30, 2009
- 64
I recently acquired a 1962 model 5224R 5.5HP Evinrude Fisherman. It is complete, but literally hasn't run in 20 years. It has a few ignition issues, and poor compression. I pulled the head and the head gasket appeared to be OK. One cylinder was just below 50 PSI, and the other was about 55 PSI. The bore is smooth and looks good. I'm guessing the problem is frozen rings.
I'm waiting right now for the PB Blaster to do its thing on 4 screws that hold the Armature Plate Support to the case so I can split the case and pop the pistons out.
I have had pretty good luck looking for most of the parts, but can't seem to find any info on the pistons or rings.
Rings (std) 486275
Piston (std) 376994
Can anyone recommend a good place for these parts and other internal engine parts? Everybody seems to go back to 1968, but not many go to 1962.
Thanks!
Rings (std) 486275
Piston (std) 376994
Thanks!
