I am trying to remove the VRO and install a Non VRO pump.trying to find which one i need to replace it. I have a 1993 Evinrude 50hp. Any help and any pics would be great. Thanks
You do not need to replace the VRO pump if you are disconnecting the VRO system. Simpley plug the oil inlet and disconnect the wires and use the current VRO pump as a simple fuel pump. However if you would like to switch it out OMC part# 5007422 is the vro replacment pump for fuel only and mixing oil and gas at a 50:1 mix it retails for around 380-400 dollars
