any help for the info i need, and can i use copper coat on gasket, thanks,JRD
M motorshop Cadet Joined Sep 11, 2011 Messages 13 Sep 13, 2011 #1 any help for the info i need, and can i use copper coat on gasket, thanks,JRD
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Sep 13, 2011 #2 Re: 1980 35-hp johnson, head bolt torque Clean both surfaces and use no sealer and torque correctly to 216-240 inch pds.
M motorshop Cadet Joined Sep 11, 2011 Messages 13 Sep 14, 2011 #3 Re: 1980 35-hp johnson, head bolt torque thank you, by any chance do you know what the ft lbs would be , thats all i have iam figuring around 45, thanks again, JRD
