The situation.
My friend has a boat with a (1987) 140 hp Johnson w/VRO which was winterized poorly one season and two cylinders had moisture in them and rusted away the rings. It was the RH side standing behind the boat. We pulled the motor and put new rings and honed all of the cylinders, which were still within spec.
We did get the motor running with 25:1 oil gas mixture while we tested the VRO. The motor smokes alot and we put a short, clear tube on the oil inlet of the VRO. Holding the tube up and making a mark where the oil level was when we started the engin. The oil level slowly drops while the engine is running, which means the VRO is pumping oil but the "no oil flow" alarm still goes off. I know that the VRO gets some imputs from the tach and if the tach is off and/or shorts in the wires may make the alarm go off. We are going to to just unhook the VRO for now and work on that this winter.
The remaining problem is that we replaced the water pump and reinstalled the lower unit. While running the engine on muffs we do not get water to flow out the tube in the motor base. We replaced both thermostats and still nothing, you can hold your hand on the heads for a while but as they slowly get hotter we shut down the engine in fear of overheating it.
I see the smaller tubes that are attached to the thermostat housing run over to a roundish type housing located behing the throttle/shift lever on the RH side of the engine and then a tube comes from there to the pisser that the stream of water should be visible from.
Can this be blocked or what is my problem for not seeing water out of the pisser?
Thanks
Thanks
