Model E175NXTAG
S/N G 03257083
Lots of good posts on methods to release the gear shift rod to lower the gearcase to replace the impeller.
I have not found any specific to my needs.
Cowls removed, top of shift rod is connected to a fulcrum piece with a PIN just below the carbs (see Pics). Currently in reverse gear.
Lower unit dropped about an inch at this point.
Is the screw/bolt to be removed still further down the shift rod or do I drive out this pin?
Hopefully the Port and Starbord pics make this (first time).
Standing by for your posts.
Jules
S/N G 03257083
Jules
