Couple months ago picked up a ugly Johnson 77' 85 HP ran good until last week clutch dog went out I assume?.... It was running ok until then it would not shift into neutral or reverse stuck in forward...
Was shopping for a lower unit and found for sale a Johnson 73 135HP w/TNT. I checked the fluids and forward and reverse on the lower unit oil was clean and green and seemed liked a good lower unit and motor......The seller knew nothing about it except it was left there many years ago..... It visibly looked mint with a lil sun fading, I loaded it on the trailer for $260.
Got home swaped motors added fuel would not stay running at idle ....I do need to replace water pump and was going to do a carb job but....got the compression gauge and checked the cylinders
1.105 PSI
2.160 PSI
3.170 PSI
4.180 PSI
What should I do now? how much would a powerhead rebuild cost? I can do everything except cylinders and lower unit rebuilds! and advice would be great
Thank you! Long time forum reader first time post!
Hello Everyone!
1.105 PSI
2.160 PSI
3.170 PSI
4.180 PSI
Hello Everyone!
