meanderson
- Sep 5, 2011
- 2
I have a 1995 Johnson outboard 115TL. The 20A fuse in the motor blew out and the tilt & starter quit working. I replaced the fuse and the engine started with throttle down, but ran very rough and would cut out when letting up on the throttle. Could not get the motor to idle, it would die out every time. Replacing the spark plugs had no affect. After trying several times, the fuse blew again. Any ideas would be much appreciated!
