Dustinfish
- Aug 9, 2011
- 46
The manual says " Cause by disconnected, kinked or clogged MAP sensor house or clogged inlet manifold gas filter." Seems easy to check but yet I can't find this hose they are taking about. Is it behind the mainfold where I can't see it? I seen the map sensor where it goes into the mainfold but that is it.
Thanks
Thanks
