I have a problem when trying to start the engine cold and I need to crank it a little more. With a new and fully charged battery, the battery seems to get drawn down quickly so that after just a few starting attempts, it won't have the strength to turn the motor over. So following the voltage drop tests in my manual, here is what I'm finding:
Test #1
Connect red voltmeter to positive battery terminal and black voltmeter to solenoid positive terminal - Crank engine - Reading should be less than 0.3 volts - Mine reads 2.6
Test #2
Connect red voltmeter to positive battery terminal connection on solenoid and black voltmeter to positive terminal on solenoid leading to starter - Crank engine - Reading should be less than 0.2 volts - Mine jumps around so much I can't get a single number????
Test #3
Connect red voltmeter to positive terminal on solenoid leading to starter and black voltmeter to positive terminal on starter - Crank engine - Reading should be less than 0.2 volts - Mine jumps around so much I can't get a single number????
Test #4
Connect red voltmeter to common engine ground terminal and black voltmeter to negative battery terminal - Crank engine - Reading should be less than 0.3 volts - Mine reads 3.0 volts
My negative ground cable is a 4 ga.
Where do I begin with these kinds of results? Thanks for your help!
Test #1
Test #2
Test #3
Test #4
