Re: 1967 80 hp evinrude speedifour loses power
Yup...they do run pretty well on 2 cyls (i have own the Johnson version of your motor). Mist the cylinders to see if the motor picks up, if not You probably have an ignition issue.
Have you done the sync-n-link per the manual? Check/replace points and condenser.
With the cowling off(not running), go to full throttle and check to make sure the "safety stop"( i forget it's real name) is not preventing the distributor from fully rotating to the full advance position. My shift linkage was not adjusted properly and my 'stop' wasn't fully getting out of the way of the distributor.
It caused me 'fits' until I finally noticed it.
