RandyJ
Master Chief Petty Officer
- Jun 13, 2002
- 808
I acquired this motor a couple of months ago, no fire, sat up a few years. To get it firing I replaced one coil and both condensers, cleaned and set the points.020. Without touching the carburetor it cranked and ran good out of the water. I put it on a small boat today and it did kind of okay when I idled out. Once I got in the open I throttled up. It slowly increased rpm but tended to sputter. The more I ran it the better it got up to a point. Then like magic it would sputter some then take off and ran fantastic for maybe 100 yards to 1/4 mile..then act like it was only hitting on one cylinder. I tore it back down to find a plug wire loosely fitting in one coil. While I had it down I went through the carburetor...spotless! The guy I got it from had the carb cleaned before putting in storage years ago. I did the ritual cleaning of everything in the carb and reassembled. Now it's a little hard to crank, still sputters and from the looks of the exhaust is running extremely rich with black oily gas/carbon coming out the exhaust. I can't tell if it's just not always firing or if it is flooding causing it not to fire. Just need a little help thinking on this ....
