hi i just bought this 91 ranger with 91 150 fast strike took it out for test run ran great 2nd time out took awhile to get on plane and wouldn't run full speed witch is around 64 mph so i got home and looked at plugs 2 were soaked so i changed out all 6 for new went back out next day and all was fine also went on vacation for 4 days ran great just last sat took her out fishing ran fine to first spot then same thing no power and took awhile to get on plan pulled into cove swapped out 1 plug that looked a little wet thought this would fix it but when i took off no change so i headed to the ramp got back home pulled out all plugs to see how they looked and the 1 plug i replaced looked like it was brand new out of the box then i checked for spark and no spark on that cylinder but even with no spark shouldn't the plug be oil soaked when not firing any help on this is greatly appreciated
