OMC-boy5.5
- Aug 16, 2010
- 51
I was out on the lake Sunday and my 57 'Rude 5.5 just kind of bogged out, struggled for a second, then died. Started right back up and on I went. Did it again 100 feet later. Started right back up and made it back to dock (200 yds). Then dropped off my dad and I went back out a ways and backtrolled along some lilly pads for about 20 minutes. Seemed to run great without a hitch. Then I started back for dock and halfway home it bogged out and there I sat. Wouldn't start. Later that evening I finally got it to run, but on one cylinder only. Kept it running for 5 minutes at higher throttle and it kept the top cylinder. Bottom plug/cylinder was cold.
I thought it may have been some (admittedly) dirty gas, but I figured it'd be fine since I have the tank screen and an inline filter.
Got it home and there is good spark in both cylinders. Tested compression: Top, 70psi ; Bottom, 1 psi
Pulled the head and this is what I found:
