I have acquired a 1979 80HP inline 4, and a 1978 115HP inline 6. The 115 is shot with a beautifull mid section, lower unit, etc... The 80HP runs great but has rough shape mid section and lower unit. I have swapped powerheads as everything seemed identical. Problem I'm running into is that motor starts great, idles great, but when you put it into reverse or forward she cuts right out. You can idle good in forward at about 4 or 5mph, but try to give it anymore and she just dies right out. I have been reading for hours trying to figure this out. Could it be that the exhaust restrictions on the 115HP Mid-section is not allowing the 80HP to get going. Heard this possibility from a retired local mechanic, and hoping someone here would know if this is/could be my issue?
Thank you so much in advance for your response. Any and all input would be greatly appreciated.
