Having a what seems to be a timing issue as title states....
Original motor was a 1989 175hp Evinrude Crossflow with 35amp (single power pack), vented flywheel
Donor powerhead was sourced from a serial reading 1985 235 crossflow with the 10 amp (twin power pack), non-vented flywheel
So, 1989-175-35-amp flywheel, stator, timer base, power-pack, coils, etc onto a 1985-235-10-amp powerhead (which originally had the non vented fly and twin ppacks)
All components on donor motor were performing perfectly prior to swap (swapped due to water in cyl - non catastrophic failure, just prevenetative)...
She fires right up but idle is erratic...cannot get her to idle on or off quickstart. Haven't gotten to WOT advance yet, but I have had her on the water and mainly idle was a big problem. In order to get her to idle properly the RPMs are too high...making shifting in and out of gear a pain. Im getting spark on all cylinders and compression is an even 115 plus or minus across all cyl...
Everyone thinks Im crazy but Im noticing a ticking coming from aft of the flywheel area, around the area of the reg/rec but it is most prominent only on the port side.
Is there a base incompatibility with the swap? Or am I missing something? Is the powerhead suspect?
