Hello everyone. Newbie to Boats, and Outboards Here.
I recently bought a 1968 55hp Johnson With the Infamous Hydroelectric Shift Of Course.
I had problems with the shifting so after recearching the issue here on iboats i installed a shift switch to bypass the one on the controll lever. This did solve the shift problem as i could now hear the shift solenoids clicking back and forth when not running as well as it was shifting good at idle. ( I was using muffs to run it out of water)
I then changed the gearcase oil putting premium blend in of course. The oil that came out was grey and frothy with water in it. Obviously a problem. I immidiatly lost the ability so shift at idle, it will occasionaly shift if i up the RPMS a bit.
I then draied the oil a second time and again it came out watery, very. Put fresh oil in it ran it for a few minutes whiile i was checking to see if it would shift and then drained a bit of oil to check it again. It was grey and frothy after only a couple of minutes of running.
It will shift from forward to reverse if i position the shift switch in either forward or reverse before i start it. This seems odd to me but it might have something to do with the water in the gearcase.
Both Solanoids read 6 ohms and there is full 12v available when they are not powered. When powered they read 10v. This seems right to me as 6ohms will cause a 2v drop if i remember my elecronics correctly.
When the muffs are on and the water is running there is water streaming out of several holes around the top of the lower unit. Is this the proper spot for the water to be coming out?
As well there is water pouring out of what looks like the lower steering hinge just above the lower unit towards the transom. This i think is a problem and would seem to indicate to me that i have some serious issues with seals being gone. I suspect that the water coming out of this last particular spot started around the time i started to have problems with the shifting, As i was looking carefully at the leg the very first time i put water to the muffs and i didnt notice it then.
Any Ideas would be Great.
