tim thompson
- Jul 6, 2010
- 53
I don't have key for the control unit so I can't engage starter motor to test 82 johnson 35hp. can you get key or by pass simply to try to start and test motor? The 9.9 is set up to start electric also. It has seperate control (standard f and reverse once in gear you can accelerate . I don't know how they started it. no key, no push button etc... anyway it pull starts and runs fine, turned off quickly though cause no water exiting pee hole. I can't find thread regarding key issue. Thanks
