Motor puts out a almost fog/steam at idle or quarter to half throttle, I realize being two stroke it should smoke, but its wild looking stuff, pee hole is clear and flows good so I'm not concerned with overheating but?????????
Pee stream only indicates that pump is working, but not that water is circulating in the engine. Pull down thermostat and 'boil' it. Should be fully opened at 150F.
