Have 1972 65hp Johnson triple, motor running fine then all at once motor lost power. Ran just enough to get back. While checking out fuel lines I notice some water just outside the front air box cover. Removed cover, tilted motor back and water came out of carbs! Pulled plugs found them wet with water. Drained lower carb of gas, pumped fuel through lines then started motor. It started ran for 5 to 10 seconds then water started coming out of the carbs again. Question: big big problem or money to fix, what could have happened?
Thanks
Thanks
