Engine - '89 Evinrude 40hp
I just installed a new tilt/trim gauge, which I purchased from ebay. Its a Faria Euro tilt/trim(omc evinrude). I have a wire coming from the tilt/trim unit, which I thought was the signal wire, I have an ignition wire from the control box and a ground wire. When I start the engine and hit the tilt button, to make it go up, the needle on the gauge goes down. When the trim kicks in, going down, the needle goes up. What is going on with this gauge. If there is any more info that I need to give, please let me know.
Thank you
Thank you
