NAVY LIFE
- Jul 23, 2011
- 37
Running motor on the hose I heard this will happen untill the thermos open.
Well I pinched the top of both thermo. off and reinstalled the as well as the white vavles too keep as much back pressure as possiable while letting the motor flush out build up that has been blocking the thermos.
from opening and causing an overheat. I will install new ones after a few trips on the water.
But about the Exhaust and lack of water at the prop could it be bad gasket in L.U. letting exhaust gas push water out the vents is this ok or must it be replaced.
Also excessive smoke. But have not installed QL77's yet
Am I just pernoied I do not want to melt this motor down. The shrimp run is on!
