Re: 1987 Evinrude 200 looper or crossflow?
I bought it! Absolute steal, too at $500. He says one cylinder bank is 85 and one is 95. Couldn't test because the only battery he had on hand was very low and had a hard time turning it over so I figured there was no point in pushing the issue. I could have pulled my optima red top and put that on it but didn't. Plugs out it wasn't hard to turn by hand. One of those gift horse in the mouth sort of things since the truth is I was going to buy it no matter what the compression test said.
So unless I can't resist parting it out and restarting my project with more funds, the plan is to tear it all down and build it from the ground up.
Things wrong:
-tilt/trim unit is removed as they were going to rebuild it since the trim motor (yes motor) had filled with hydraulic fluid. included the oem tnt kit.
-no spark. he said he resistance tested everything (but not voltage) and the stator was bad. he replaced it with a new (used) stator that he said passed.
-steering arm assembly, the one that runs down from the powerhead into the midsection, is a little rusty, but nothing awful. he had already purchased a new arm and gave it to me with the motor. the bolts on the current arm look great so that should be no problem with the powerhead off.
-skeg is in Bad shape but the rest of the LU seems ok. the prop shaft turned when I bridged the starter solenoid. it looks like a hard impact just below the gear housing and bumped up then came down on the back of the skeg and snapped it off. It really probably is fine but if it's not I don't care because luckily I happen to have a V6 lower lying around....
So some time after I can figure out how to get it out of the truck I'll get a rebuild thread started and have at it. It took the two of us over an hour to get it off the stand he'd made and into the truck, and he had a fork lift. Good luck to me on that one! I don't have a forklift by the way.
