I have a 1958 Johnson 10HP Model QD-19 that I recently got running thanks to the iboats forum. My only trouble is that the motor cover (the hard metal shell kind) does not fit right on the motor. It is the original motor cover, but it sits slanted forward when I put it on and does not sit level. Its not a huge problem, except when ever I lift the motor out of the water, it pops off. Is there a special procedure to putting this on? I can never get all the rubber stops to line up in the correct position. If i put the back part of the shell on first, the back rubber stops fit, but I cannot slide the front over the control assembly panel of the high/low speed adjustments. If I put the front on first, the back rubber stops do not line up with the stops on the engine. Either way, the cover never goes on. Also, I cannot figure out with the rubber strap piece under the cover is supposed to attach to. Any help is greatly appreciated.
