I have a 1980 140HP Johnson V4 outboard. It idles fairly well. At about 1/3 to 1/2 throttle it starts sputtering and will sputter out and die if left in this position. When I move the throttle past a certain point it will clear it's throat and take off as it should. Does this sound like a carburation or a timing problem? I don't see any adjustments on the carburetors and I don't have a clue how to time one of these. Any help would be appreciated.
