I had the carbs synched and everything gone over. The motor idle with water hose attached. The mechanic did not take it to the lake though.Providing your carbs and throttle plate housing are clean and working, mix screws properly set, the idle rpm is set by moving the tab marked 'LOW' on the spring loaded sensor bracket on top of the flywheel cover.
