Hi guys,
On my 1976 evinrude 40hp there is no cooling water coming from the leg. I have fitted a impeller to correct way, put a hose pipe on the water tube and water flows around the engine and out. The intake is clear. When it runs only a trickle of water comes out? No idea why this is. The water tube is correctly installed into the impeller housing and the wooddruff key is engaging.
Any ideas?
Any ideas?
