I just acquired a 1984 Evinrude 9.9hp outboard model: E10BALCRA, AC Lighting rope start. So it is fitted with AC voltage feature supposedly putting out 300 volts AC. There is a plug in outlet on the LH rear side of the upper lower cowling that has a rubber plug cap the covers the outlet. The outlet is 3 prong male connector. I need to know how and what to plug in here to achieve:
1. power to boat navigation lights without battery. In doing some research I think AC lighting kit #584864 may work but not sure.
2. convert voltage to dc to charge a battery. I believe i need a voltage converter/rectifier and other hardware but don't know what.
Any suggestions would be greatly appreciated.
Thanks.
D.
Thanks.
D.
