BonairII
- Jun 7, 2011
- 2,727
Guess I should start a new thread cause my motor isn't bogging anymore, now I can't seem to keep the port side cylinders running.
Quick overview:
Compression is 90psi across the board
Starboard cylinders are running fine (I pulled plugs one at a time and engine stumbles/dies)
Port side cylinders are not getting fuel, i think. Plugs are dry. Pulled plug wire and idled motor...plugs still dry afterward.
Misted starboard carb and motor "poofs" out the exhaust(maybe it's a sneeze, maybe not)
Misted port side carb and engine stumbles and dies
I would assume the port side carb feeds the port bank of cylinders, correct? If this is the case, I have no idea why misting the port carb would stall the motor cause that bank of cylinders isn't running.
Cleaned carb out for the third time yesterday and it ran great. Got boat up to 33mph with lots of low end power. Docked the boat last night and started it today...and the 2 cylinders were not firing AGAIN.
Quick overview:
