Re: OMC 115 Turbojet Engine coupling needed
Thanks you were right on the money. Got that replaced and found out the gear set 0437521 is bad. Appears the needle bearing gave and wiped out the shaft. That then took out the coupling.
I have looked around and the best I can do is new on that gear set and shaft. Would you know of anyone that would have a used one available.
