hey guys, I had purchased a doral bowrider with a non cranking engine, i disassembled the engine to find that one piston had hit the head , piston was cracked and the wrist pinhad engraved the cylinder walls. seems as if the rings have let go and got jammed cracking the piston not sure. I sent the bare block to get sleeved and rebored jsut got it back about to reassemble. I am wondering is there anything i need to look out for while reassembling any tips. any other parts i should replace before running this engine. currently i am replacing all pistons and bearings in the powerhead thermostates and lower end fuids. also boysen reeds
also can i run the engine with muffs how long and what rpm
Thanks
Thanks
