Stuck thermostat 1989 J70TLCEM Help!!!!!!!!
roger46982
Checked the stat on my 89 Johnson and it is stuck. What problems will this cause and what thermostat do i need and where can I get it? Help!!!!!
Haffiman
Re: Stuck thermostat 1989 J70TLCEM Help!!!!!!!!
If you still have the 'old' version of thermostat, a vernaterm in a white housing with 3-fins going into a rubber bushing, replace it with the newer version!!
Should be automatic if you order on the old part number from a dealer. Remember however to change the rubber seal and cup with the new 'plastic' seat that fits the new version.
The new number is 0434137 for the thermostat.
roger46982
Thanx Haffiman, fins go toward the engine?
Haffiman
Yes. I thing the new version is black or brown, has no fins, only a cone.
roger46982
Thanx for the help!!! Am I correct in thinking that the engine most likely won't operate well if not at the right temp? Been having a problem with it not idling.
Haffiman
It will normally 'sneeze' as it got a cold!
roger46982
Got the parts, what is a good way to get the old cup and seal out?
Haffiman
Just flip it out with a screwdriver.
You may have to give the cup a 'knock' and deform it, but no big problem.
