Hi,
I am currently trying to replace the entire steering system on my older pontoon boat which has a Johnson 90HP (from around 1983) outboard engine. After looking at one possible solution, it states that it will not work with "older engines with thru-transom OMC engines" - see specs below.
Does anyone know what 'thru-transom OMC engines' refers to? I tried calling the seller but they were unable to help me. I would like to know whether this will work with my Johnson 90HP outboard?
Thanks in advance!
PreTech Steering System.
This pontoon boat steering system cuts installation time in half and occupies a minimum space behind the dashboard, fits perfectly with our pontoon boat consoles.
Can be used on pontoon boat engines up to 140HP
All boats with inboard/outboard (I/O) engines
*no older engines with thru-transom OMC engines
-Standard ?? tapered shaft
-Three turns to lock for standard travel
-All Stainless Steel ends to minimize corrosion
Our kits contain:
Pretech rotary helm
Steering Cable
90 degree bezel and all installation hardware
Thanks in advance!
Our kits contain:
Pretech rotary helm
Steering Cable
