Is there some sort of "trick" to reinstalling the lower unit onto the motor housing? Specifically I am wondering about the shift rod. How do you position the rod to mate up with the handle and vice versa? Do you put the shifter in neutral, and then twist the shift rod to the middle position? Does his work? Do you put the shifter in the forward position, and then turn the lever clockwise or counter clockwise? This is where i am wondering if there is a servicemans trick to doing this. I was trying to keep the shifter in the middle, and get everything to line up, but it was not working. I will try again late today. Thanks.
