BC ClearwaterFL
- Jun 17, 2007
- 25
hello I have a 1995 johnson oceanrunner 200
on a wellcraft it has a water pressure gauge on it what should it read? at idle?and during running I think it will depend on the rpm as to what the psi will be but at idle it should be something right?
I just had my power head rebuilt and am being cautious about everything it took a big chunk out of my wallet.
the mechanic says the gauge is shot when it went in for the work it worked fine. I think he's setting me up for more work you would think he would have checked every thing out after I committed to him working on it for me another mechanic had negative opinions with him.I just figured he was trying to get my work.
any way I put low pressure air on the hose going to the gauge and it registered. any thoughts?
I see the tell tale stream and for some reason it just don't look as a full stream should,am I being to cautious?
