Re: Once I hit 3000 RPMs the motor starts bogging down - 1989 Johnson 150 HP Outboard
When running the bulb should look round-normal, but should be soft to the touch. If it starts to collapse on itself, that is a (bad) sign of a fuel restriction or a bad fuel line bulb. The pump is drawing more fuel than the hose (or tank) can provide. Almost like the fuel tank might not be vented... Check the anti-siphon valve (if you have a built-in tank) to make sure there is no crud in that ball valve restricting it's movement. I saw a restriction in a fuel tank years ago: a band-aid got sucked up in the fuel tank pickup and it would not draw fuel.
Well, here are the results of today's test:
Constant alarm is sounding from the first time i turn the key on.
Fuel bulb was replaced, and ran directly from an auxiliary fuel tank.
when the motor topped out at 3000 rpm's, i compressed the bulb until it was hard as the engine was running, no change. at one point, i started the motor and the alarm didn't sound, but that didn't last more than 2 starts.
when i'm at 3000 rpm's.. the boat is at WOT and deep in the hole. i'm guessing 10-15mph..
Also, the tach only works sporadically.. i don't know if this is a symptom, but i have a new tach gauge i can install to see if that fixes THAT issue.
So... what should be my next test? does this look like a restriction in the motor? fuel filter or a dying fuel pump? Thanks in advance!!
