hello guys, new to the forum, but it looks great lots of good info thats helped me a ton already. But now i'm having a problem i cant figure out. I have 74 ouchita bass boat, with 74 70hp evinrude model 70442 with selectric shift. Ok now heres the problem, when the boat is in foward it acts like its kicking in and out of nuetral, it will go but,(trying to think how to explain it it would be easier to make noises...lol) so its in foward and going but it keeps jumping real hard like it went into N then back to F and the faster you try to the harder it jumps when it kicks out i know its not the carbs or spark it has to be in the lower, im sure that its kicking out what should i check first before i tear into it.....and the reason i say its not the carbs i just fixed everything else had it running great then bam this happened oh and it seems to fine in reverse(of course i couldn't go very fast cause it pushing water over the back...but i did check it and it worked fine) thanks for any help!!
