The FAQ "Johnson/Evinrude Cold Start Procedures" is a great reference for cold starting my 1986 Johnson 150. The question I have is, when do you not use the primer bulb or the electronic primer solenoid when starting the engine. For example, would a four hour stop at an anchorage/sandbar require priming the primer bulb and utilizing the primer solenoid at start up, or do you forget about the primer bulb after the initial start for the day? Any thoughts on when not to use the primer solenoid and/or primer bulb? Is it a correct assumption that priminig the primer bulb at all starts should not be detrimental to an engine start ? Thanks for your comments.
