I installed a new key start switch the other day and it had three screws on the back labled igniton, bat, and sol, the old switch i pulled out however had 4 screws, 2 for ignition, bat and st, i hooked the wires for ignition to the one on the new switch and took a guess on the other two. and today when i hooked a battery up and gave it a test i got a noise from the engine, im guessing the solenoid, but the started did not engage, and then i pulled the switch out to look over the wiring again and i got an ark off of another wire that was not hooked up and now it dosnt even make the sound on the engine.
First i would like to know if i wired the key start wrong or if its something else
Second i would like to know if i shorted anything out and where to start looking for the solution
and third i would like to know what would have stoped the starter from engaging
the motor is a 69 johnson 55 loop charged
thanks
thanks
