We boat is on trailer with garden hose attached I can shift in and out of gear with no problem and cannot duplicate the problem. When boat is on the water and I shift out of gear I must go a little past the shift detent point to get it to come out of gear. I can't understand why it shifts perfectly on trailer/garden hose but must go extra travel on shift lever to come out of gear while on the water. The motor does idle at a lower RPM on the water (I think due to water back pressure on exhaust) than when running on the garden hose. I don't think this should effect shifting out of gear.
Johnson 2005 90 HP 2 Stroke
Center console
About 60 hours on engine
The boat was like this when I bought it used
Center console
